Error "Query body must contain a query hash" when searching contacts
  • January 28, 2024
  • 48 views
Hello,
I trying to search by using the “POST /contacts/search” API. If I call the API from either POSTMAN or form the JSON as string, everything works fine. But when I trying to serialize an object to JSON and call the API, I get the error “Query body must contain a query hash”.
This is from .NET API.
Scenario which works
var json = JObject.Parse($@"{{
    ""query"": {{
        ""operator"": ""AND"",
        ""value"": [
                ""field"": ""email"",
                ""operator"": ""="",
                ""value"": ""{email}""
var jsonStr = json.ToString();
var postData = new StringContent(jsonStr, Encoding.UTF8, "application/json");
using (HttpResponseMessage response = await httpClient.PostAsync($"/contacts/search", postData))
Scenario which results in the error
var searchQuery = new IntercomSearchQuery
    Operator = "AND",
    Value = new List<IntercomSearchValue>
        new IntercomSearchValue
            Field = "email",
            Operator = "=",
            Value = email
var searchQueryStr = JsonConvert.SerializeObject(searchQuery);
var postData = new StringContent(searchQueryStr, Encoding.UTF8, "application/json");
// Classes
using Newtonsoft.Json;
public class IntercomSearchQuery
    [JsonProperty("operator")]
    public required string Operator { get; set; }
    [JsonProperty("value")]
    public required List<IntercomSearchValue> Value { get; set; }
public class IntercomSearchValue
    [JsonProperty("field")]
    public required string Field { get; set; }
    public required string Value { get; set; }
Question
Would love some guidance on what I might be doing wrong here?
Hi @mitren-usapath ! Ebenezer here from Engineering Support👋.
Could you add a 'Content-Type' header with the value of 'application/json' to see if that returns a successful response?
Let me know if this works for you
