Issues with Webhook Authorization for OAuth Integration
  • June 3, 2024
  • 91 views
Description:
I am encountering issues while integrating Intercom webhooks using OAuth. Although the OAuth flow works and I can obtain access tokens, I am unable to create webhooks due to unauthorized token issues. I have selected all  available scopes in the Intercom Developer console, but the issue persists.
Error:
  "type": "error.list",
  "requestid": "003avbbpvjpgktcsppvg",
  "errors": [
      "code": "token_unauthorized",
      "message": "Not authorized to access resource"
How To Reproduce:
  • Request URL / Headers:
    URL:  POST https://api.intercom.io/subscriptions
    Headers: Authorization: Bearer <access_token>
  • Authentication method or app type: OAuth 2.0
  • errors: token_unauthorized: Not authorized to access resource
Let me know if you need any additional details.
Could you please assist in resolving this issue so that I can successfully create webhooks?
Thank you for your support.
Hi adityakanade, It’s Mat from the Support Engineering Team 😀
I am not sure where the issue is here but please follow the article below to set up Webhooks properly with
the desired topic. 👇
https://developers.intercom.com/docs/webhooks/setting-up-webhooks/
If you come across any more issues, please reach out to us via Messenger in your Intercom workspace so we will have more visibility on what's going on with your setup.
