I can see two different URLs in OAuth Process and Installation. Do both of them talk about same URLs? (Please check the attached screen shots)
Both are same URLs?
Best answer by Eric Fitz
Hey @rajabdeen
In the two images you have linked, these refer to different URLs.
The first image is talking about direct installation and uninstallation URLs. So for direct installation, you would insert the URL that kicks off the OAuth flow.
The second image is talking about redirect URLs.
This is the URL which we POST to when your user has authorized your app to access their information. In other words, it's the URL that Intercom will use to send the authorization code for your user.
You can add more than that on the redirect URL, but that is optional.
Join the Intercom Community 🎉
Login to the community
