Create Hubspot Ticket from Intercom
  • February 14, 2024
  • 9 replies
  • 558 views
TJ B12
Hello,
I’m looking for any possible ways we might be able to create a Hubspot Ticket from within Intercom.
Our use case is this: our Support Team directly supports our customers via chat and email in Intercom. If an issue is identified that requires Engineering help, we create a Ticket in Hubspot for Engineering to pick up.
I’m looking for solution so that our Support Reps don’t have to keep a tab open in Hubspot to manually create tickets.
Any possible ways to do this?
Best answer by TJ B12
Andrew Underhill wrote:
@TJ B12  did you figure this out? I’m looking to do the exact same thing
I did, finally, after a lot of trial and error.
Here’s a look at what the request looks like:
Set up your authentication token
HTTP headers
Request Body
In the request body is where you’ll map your fields. Mine looks something like this:
{"properties":
  "hs_pipeline": "<pipeline_id>",
  "hs_pipeline_stage": "<stage_id>",
  "hs_ticket_priority": "<intercom_attribute>",
  "subject": "<intercom_attribute>",
  "content": "<intercom_attribute>",
I hope this helps get you going!
I head out for vacation tomorrow, but happy to check back when I return to see how it went!
bernice
  • 230 replies
  • February 19, 2024
Hi there @TJ B12 👋  To create a HubSpot ticket from within Intercom, you have the option of using Custom Actions along with the HubSpot API to create tickets. You'll find more on Custom Actions in this article from our Help Center 📌
Please note that the Intercom HubSpot app only sends data one-way from Intercom to HubSpot and cannot sync data from HubSpot to Intercom. If you want to sync data from Hubspot to Intercom, you can check out the Data Sync by Hubspot app which allows a bi-directional sync. For more details, check out this article on the integration.
Hope this helps! 🚀
TJ B12
  • 11 replies
  • February 20, 2024
Thank you @bernice
TJ B12
  • 11 replies
  • March 18, 2024
Following up here - might anyone have any examples of what it looks like to set up a custom action specifically for Hubspot API?
I’m having a bit of trouble working everything out, and if there were some example I could see it would be wonderful.
TJ B12
  • 11 replies
  • June 11, 2024
HTTP headers
Request Body
{"properties":
Sweet! Thanks, this is helpful. Did this involve creating a Private App in Hubspot? If so, do you know what permissions you had to give it?
TJ B12
  • 11 replies
  • June 11, 2024
Ah, yes, it did!
Only Scopes needed was for ‘tickets’.
Ok I got a successful test. One more question, since you’ve been so helpful.
Can you illustrate how you connected a ticket/request to a user and/or company in Hubspot?
TJ B12
  • 11 replies
  • July 19, 2024
Hey @Andrew Underhill , sorry for the long delay in reply here! Have you got this part sorted?
If not, here’s what I did
  1. Set up an Intercom Custom Attribute (Companies) for “Hubspot Company ID”
  2. Set up a sync in the Hubspot ↔ Intercom Integration in Hubspot to sync the Hubspot id to the Intercom custom attribute
  3. Now that you are syncing Hubspot Company ID from Hubspot to Intercom, you can use it as a variable in your payload when creating your ticket, adding an Association:
    "associations": [
       "to": {
        "id": "<hubspot_company_id>" },
        "types": [
           "associationCategory": "HUBSPOT_DEFINED",
           "associationTypeId": 339
I believe that about covers it!
Would love to know how you have fared with your adventure!
