3CX is a hosted telephony solution and I would like to know if it is possible to connect with Intercom.
How can I integrate Intercom with 3CX?
Best answer by Aparna
Hey @chris h14 ! I would suggest you check with their support to see if they have any integration with us.
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
