React Native EXPO: 404 Resource not found
  • September 25, 2024
  • 122 views
Hi there,
We have issue with the mobile SDK “@intercom/intercom-react-native” when trying to integrate it with our APP with Expo.
Below is the sample code we ran with local development build with iOS/Android simulator
try {
          console.log('==== SIGN IN ====');
          await Intercom.loginUnidentifiedUser();
        } catch (error) {
          console.error(
            error.code,  // 101
            error.message, // Error in loginUnidentifiedUser
            error.userInfo?.NSLocalizedDescription // HTTP Error: 404 not found
environment variables & dependencies version:
  • @intercom/intercom-react-native - v7.2.1
  • expo SDK: v51.0.31
  • react: v18.2.0
  • react-native: v0.74.5
Any idea?
Kind regards,
Best answer by Oseas
This was solved via support conversation.
For anyone running into a similar issue, please make sure to check you’re pointing your Intercom instance to the right region. For example, if your workspace is hosted in the US, you’ll need to specify “US” for the intercomRegion attribute within the expo object:
You can find our documentation for Expo here.
Sometimes can be tricky to know exactly what region your workspace is hosted (thanks to @stinglin for flagging that). But an easy way to find your hosting region is by checking the URL of your workspace. The URL will differ based on the region:
  • For US-hosted workspaces, the URL will be app.intercom.com.
  • For EU-hosted workspaces, the URL will be app.eu.intercom.com.
  • For Australian-hosted workspaces, the URL will be app.au.intercom.com.
Hope that helps!
Update
Android simulator was able to loginUnidentifiedUser, but after calling
Intercom.presentMessageComposer()
// or
Intercom.present()
It is showing “something’s gone wrong”
  • September 29, 2024
[Problem solved]
It was caused by the region of the workspace:
"intercomRegion": "US"
One suggestion: it would be great to show the region in the workspace portal interface to save us time to trouble shooting.
Big shout out to support team. Thank you.
Oseas
  • 103 replies
  • September 30, 2024
Hope that helps!
