I can't set up Zendesk and intercom integration. I wrote from one mail to both Zendesk and Intercom. And this data is not visible
Why is my Intercom customer data not showing in Zendesk?
Best answer by Eric Fitz
Hey @карина, Intercom's Zendesk integration allows you to view your Intercom customer data from within Zendesk, and allows you to manually create a ticket in Zendesk from a conversation in Intercom. Our article on this integration goes into more detail on this!
It doesn't automatically sync Intercom conversations with Zendesk tickets and vice versa.
With that in mind, can you give me a bit more detail on the exact issue that you're facing?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
