Addons for remote support
Diogo Silva
Innovator ✨
Hi guys, does anyone know if we have any addons for remote support? A company I work with had this question and at least I couldn't find it.
Best answer by Nathan Sudds
@Diogo Silva there’s not a built-in Remote Support option but you can definitely check out some of the 3rd party integrations for co-browsing or remote support that might meet your clients needs.
For example Zoho Assist might be your best option, they have a Zoho Assist integration with Intercom
You’ll find a few other options in the app store that support co-browsing but not sure about Remote Support directly.
  • 296 replies
  • January 20, 2025
Diogo Silva
Innovator ✨
  • Innovator ✨
  • 26 replies
  • January 20, 2025
Wonderful Nathan, thank you very much, I'll look into it now!
