Article URL
  • September 23, 2023
  • 254 views
Hy I am new here. Can I edit the article and change its url after posted it?
Best answer by Racheal
Hey @rohan Racheal from the support engineer team here👋
Definitely! The URL of an Article is based upon it’s title, so when you update the title the URL will change as well.
  • 512 replies
  • September 26, 2023
  • September 28, 2023
ok thanks
  • May 9, 2024
Can we remove the article number after the article? For instance, I would like to remove the 182 in the following URL.
http://help-center.test/myapp-26/en/articles/182-thanks-for-everything
  • May 12, 2024
Which is good short or long url? for example: https://dronesurveysworld.com/how-high-can-a-drone-fly/
