Articles are not showing in Messenger.
The user can see the article title, but when selected, the article screen goes blank. I have checked article and messenger settings to make sure everything is set up correctly. What am I missing?Screen Shot 2022-04-29 at 8.52.23 AM
Best answer by Kevin Bendixen
@meghan j​ Then you should contact Intercom support to see if they can help. It's not a general problem, because it's working in our messenger.
Kevin Bendixen
Is it working for you, can you open the articles in the messenger?
The first things to try out would be, using a different browser, using a private/incognito window, disabling all browser extension,s and deleting browser cache and cookies.
  • May 2, 2022
I have tried a different browser, used an incognito window, disabled browser extensions, and deleted history/cookies. No luck. Still having the same issue.
Kevin Bendixen
