I want to have one article in which I list a collection of FAQs. However, I would like the reader to be able to search for what they need. I tried the "insert code" option to create a search bar but it didn't work. Is there a way to insert a search bar into an article?
Can I insert a search bar into an article?
Best answer by Kevin Bendixen
Not possible. The insert code option is simply for formatting your text to look like program code. You can't insert code that would then be executed.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
