Can we change the redirections on the articles?
  • March 29, 2022
  • 126 views
On our help center we have articles that have been rewritten and changed url, the link of the old articles is still available on some sites. The link of the old articles redirects to the new one. The problem is that on some links we end up with 4 redirects before reaching the right page. Is it possible to change this behavior?
Exemple : https://docs.wooclap.com/faq-en/1-getting-started/do-the-participants-have-to-create-an-account/p>
Screen of redirections :
Best answer by Kevin Bendixen
@thomas s11​ I don't think there is a way to change anything for all redirects. You could manually change the old links to the current URLs, that way there would be no redirect at all.
Kevin Bendixen
