Export of articles from knowledgebase.
Hi, is there an option to export certain articles from our intercom article help center?
kind regards
Best answer by bernice
Hi @Julius Vinnemann πŸ‘‹ You can export articles from your Intercom Help Center using the Articles API. You'll find more on this in our Developer docs and in this article from our Help Center - Formatting and exporting your articles with the Articles API  πŸ“Œ
bernice
  • 230 replies
  • May 13, 2024
Thank you @bernice
Hi @bernice, managed to utilise the API for extracting metadata of all the customer facing articles in the help center. Is there a way to export internal facing articles from our knowledge base as well?
Thanks in advance.
  • August 2, 2024
Hi, @Julius Vinnemann
You can export specific articles from your Intercom Help Center using the Help Desk Migration, an Intercom partner, available in the Intercom app store.
Export up to 20 articles for free. If you need to export more, a fee applies.
Easily migrate articles based on their status and match article fields accordingly.
Try the free Demo Migration to ensure it meets your expectations. Select up to 20 specific articles by their IDs and export them to see how the migration tool works.
thank you @K.Butkovska
