Can I change the default layout of the Help Center? I want to upload my own custom HTML/CSS.
How can I change the HTML/CSS of my Help Center?
Best answer by Eric Fitz
Currently, it’s not possible to change the default layout of the Help Center, beyond some customisation options.
You can’t upload your own HTML or CSS to the Help Center.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
