How can I create callouts in an article via the API?
Hi! Based on the article about formatting articles, https://www.intercom.com/help/en/articles/4103903-formatting-and-exporting-your-articles-with-the-articles-api, there doesn’t seem to be a way to POST an article through the API that has callouts. For instance:
Any ideas on how this might be possible?
Scot
Best answer by cameron.gumley
Hi @Scott A -- Cam from the Intercom Support team here!
You’re observation is correct, at present there isn’t a way to add ‘callouts’, like the yellow box in your screenshot, when creating an Article via API. It just isn’t something that is supported at the moment nor is there a viable workaround for this other than manually adding the ‘callouts’ from within the Workspace UI (less than ideal I know).
The ability to add ‘callouts’ when an Article is created by API has come up with other customers previously and has been submitted as a Feature Request to our Product Development team - I’ll go ahead and add you to the FRQ so the team is aware of your interest in this. Hopefully it’s something we see added in the near-future 🙏
Hope that at least helps clarify whats possible at the moment!
  • 109 replies
  • January 1, 2024
Any updates on this? 😇
Chris Boerger
I need this too :)
  • December 9, 2024
Hi, I also would like this. Additionally, could we get the ability to change the colors of the callouts to our product colors?
