How can I find the Help Center section ID?
How can we get the section ID of Help Center from the UI?
If I use the list all articles api, for any given article if "parent_type" is section, what does "parent_id" signifies? Can I find that id in the UI?
Thanks in advance!
Hi @shraddha a​ ,
Q - what does "parent_id" signifies?
A - Parent_id is a collection ID.
Q - Can I find that id in the UI?
A - Yes, You can.
renditionDownload
  • Expert User
  • 1152 replies
  • May 13, 2021
Hi @shraddha a​ ,
A - Yes, You can.
renditionDownload
  • May 13, 2021
even if it's a section - the parent id will be id of the collection the section is part of?
  • May 13, 2021
Screen Shot 2021-05-13 at 5.52.47 PM@roy s11​ where can I find this section ID in the UI?
Thank you!
