How do I change the text colour in the header?
  • September 7, 2020
  • 403 views
I have a light background colour as my header, however the text is white and illegible. How do I change the colour of this text?
Best answer by Eric Fitz
Hey @iand​, the header text is always white - this colour can't be changed. I'd recommend using a darker background colour in your header image, or else uploading a header image which contains header text as part of the image.
  • 1630 replies
  • September 8, 2020
