Is there a way to select multiple collections to have the same article. Instead of having to add the same article one by one to each collection?
How to add articles to multiple collections?
Hi @nora c , How are you?
Afraid it's not possible to assign an article to more than one collection.
The best way to do this, copy the article and create a new one :/
Can you describe your use case?
Here some helpful blog post about design help center articles:
https://www.intercom.com/blog/knowledge-base-best-practices//p>
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
