I have set up Google Analytics for Help Centre. I want to track the Source from where I get maximum traffic, No of users, and articles with the most views. Any recommendations?
Best answer by Keerthi
That's basic enough if you want those metrics. Google Analytics works well. But the overall number of views & who viewed it, the reactions etc. can be obtained from the Articles Report within Intercom. If the source and breakdown of those metrics by source are important to you, then sure go ahead and use google analytics.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
