Importing hundreds of web pages into Help Center articles?
  • October 26, 2022
  • 220 views
We want to import hundreds of .htm URLs into their own respective Help Center Articles.
I see it is possible to import help documentation articles with Zendesk, but is it possible to automate an import of hundreds of .htm URLs into their own respective articles as we are aiming to do? Just looking for some guidance on how to begin this process, rather than copying and pasting each article over to Intercom manually.
Thank you.
Best answer by Kevin Bendixen
I'm not completely sure, but you might be able to do this with the API
Kevin Bendixen
  • 269 replies
  • October 27, 2022
Chris Boerger
  • March 27, 2024
Hi, Is there still no way to do this ? Apart from copy paste ?
Using the API requires a dev…
@Sriya did you find a solution?
TBelevska
  • 9 replies
  • June 12, 2024
Hi @Sriya
Here are a few options for importing hundreds of .htm URLs into Intercom Help Center, depending on your source:
  1. From Another Help Desk System: Use a third-party app to directly import your Knowledge Base into Intercom without manual input.
  2. Updating Internal Cross-Linking: Export your Knowledge Base from the source platform to Intercom and request customization to update cross-links between articles.
  3. From a Blog or Help Center on Your Site: Consider using automated data migration software that can develop a custom solution for importing your web pages into Intercom.
Best of luck with your data migration!
