Is there a way to add a custom header navigation bar at the top of the HC, to replace the default header?
I'd love to create a unified header navigation experience across some of our web properties (HC, Academy, Community), so it feels more seamless for customers when moving between properties.
Best answer by Kevin Bendixen
Don't think there are many customization options for HC unfortunately
Kevin Bendixen
  • May 20, 2021
Bummer, thanks though @kevin b​.
