Is there a way to use a persistent article link inside of another article?
  • December 23, 2021
  • 313 views
 It's a real PITA to have to go and update links everywhere if you change the title of an article (which changes its primary URL).
Example: I have an article titled "Example Article 1" that I wish to link to from within other articles. If I use the primary URL for the article - e.g., http://support.mysite.com/en/articles/12345-example-article-1 - then if I change the article title in the future I'll have to find and change all links to that article. Is there really no way to insert a persistent link for an article - a URL that doesn't change if the title changes?
Ideally there would even be a way to specify an internal article link that automatically generates the right URL even if you change the help center domain - e.g., from support.mysite.com to helpcenter.mysite.com.
This is pretty basic functionality for any wiki or other simple content mgmt system.
Best answer by Eric Fitz
Hey @user2174​, if you change the title of an article, existing links to this article will simply redirect when clicked. There should be no need to go back and manually update these!
  • 1630 replies
  • December 24, 2021
