Is there any way we can delete User Notes on Intercom?
Running Zapier from google drive to intercom to add information into user notes, however it will keep piling on instead of editing the existing notes, and it becomes a huge eyesore and can be very confusing to new staff. I have played around but can't find any way to remove a User Note. Any way around this?
Best answer by Eric Fitz
Gotcha, thanks for clarifying! Currently, there's no way to delete these notes outright (a feature request for our @Product Wishlist​ group!)
However, you can click on them to edit the text and delete all of the text contained within them. An imperfect solution, I know!
  • 1630 replies
  • July 1, 2021
Hey @user691​, just to be sure, do you mean notes added in the user's profile, or in a conversation with the user?
  • July 2, 2021
Hi Eric! I mean notes added in the user's profile :)
  • 1630 replies
  • July 2, 2021
  • February 22, 2022
Just wanted to comment the same thing happens for company notes.
  • August 24, 2022
I need to delete user notes too.
  • October 3, 2022
It doesn't work as it shows "Cannot save an empty note" :(
  • April 5, 2023
Hello - Theres been a suggestion to just delete the contents of the note, however that does not work. Is there any update on this as it was 6 Months ago.
Pierre G
  • 12 replies
  • June 12, 2023
Here is what our team does. It’s definitely not a nice solution though since it still takes up extra space…
Deleting user notes SOUNDS like an easy to implement feature, though you can’t really guarantee that since we can’t see the back-end. The back-end code could be a tightly woven web that’s hard to work with.
I see this is popping up regularly, I wonder if in this case it’s better to use a custom attribute instead of User Notes when it’s something that is only temporarily needed and content will be updated again later? Is the custom attribute just not prominent enough and that’s why it’s not being used in this case?
Pierre G
  • 12 replies
  • June 15, 2023
In my screenshot, this was not a case where a temporary note was added.
It was an angry support agent leaving a few “bad notes” on the user that I’ve had to delete.
In this case the notes cannot be removed, but it would’ve been nice to be able to do so.
  • October 24, 2023
This seems silly that this has been an open request for 2 years and you still can’t delete notes.
