At the moment if I add a link to my posts it opens in a new tab, which opens in a logged out state. This is a pretty poor experience for the customer. Is there a way for the link to open in the same window?
Links in posts opening new tabs
Best answer by Racheal
Hey
We don't have a way to manually define whether a link opens in the current tab or a new window right now, but I'll submit this as a feature request so our product team sees it's something you're eager to be able to manage!
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
