Hi,
is there a way to add opening text in a collection bfore the part that addresses to the articles in it?
For example to add it in the pink form as shown in the screenshot attached
Best regards,
Milena
Hi,
Best regards,
Milena
Best answer by Milan
Hello
The only additional thing you might want to add would be to turn on descriptions for each article and collection to be visible on Collections pages. If not on, descriptions were showing only on your main page.
Note that in your screenshot, the listed articles belong to “processes” collection which already shows “Management of various processes and statuses” as your description. So the only additional thing would be to show Articles description which will show under each article title… or you might want to add SubCollections to each group of articles on that page and set its title and description.
Hope this helps.
