Removing "Watch on YouTube"
Hi -
Love the YouTube embedding, but I am wondering if it is possible to remove the "Watch on YouTube" in the corner? Thank you
Best answer by Kevin Bendixen
@mack​ If you're using the embed option, e.g. in articles etc. Then no, you can't remove this, as you only paste the video URL. Only thing you can do is use the dedicated embed code from youtube, there you can play around with the attributes. See this post for some solutions. But this would only work in emails, and maybe only if you compile the whole message in html.
  • 1630 replies
  • August 31, 2021
Hey @kevin b​, do you have much experience with YouTube embedding? Might you be able to help here?
Kevin Bendixen
  • August 31, 2021
Understood, thank you both
  • June 26, 2022
Why is there no longer the option to embedd a youtube video in an email?
