Why is our help centre showing as "Not Secure"?
Best answer by Kevin Bendixen
@user444 I assume you created a custom URL for your help centre, have you followed these steps: https://developers.intercom.com/installing-intercom/docs/set-up-your-custom-domain?showHidden=f2cb6#section-choose-to-configure-ssl-optional/p>
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
