Bulk segmentation
  • January 21, 2021
  • 165 views
Hi,
I'd like to create a segment for ˜300 specific contacts, according to their IDs
How can I do it, instead of manually typing their IDs?
Best answer by Kevin Bendixen
@user289​ as long as the file has the corresponding emails and names of the users that's not a problem. Intercom will simply update the existing users, in that case, add a tag.
Kevin Bendixen
@user289​ You could do a CSV import. Those contacts will then be tagged automatically
  • January 21, 2021
@kevin b​ The contacts already exist in the system. Should I re-upload them, with a specific attribute?
Kevin Bendixen
  • 269 replies
  • January 21, 2021
  • January 21, 2021
cool, thanks!
