How can I import Company tags?
  • October 12, 2020
  • 364 views
Sometimes I need to tag hundreds of companies with the same tag e.g. "Integrated Company". I can't find a convenient way to do that in bulk all at once. Any suggestions?
Hello @ashley f​ ,
It's easy to apply tags in Bulk, just apply a filter to your companies and then click "Tag" (Without any selection).
Apply Filter
  • Expert User
  • 1152 replies
  • October 13, 2020
Hello @ashley f​ ,
Apply Filter
  • October 13, 2020
@roy s11​ Thanks for helping me out. Sorry I wasn't more clear. In this case I am using tags as a filtering mechanism, so the filter doesn't exist if that makes sense (until I apply the tag!). For example, I have no way to filter for "Integrated Company" and then apply a tag.
  • Expert User
  • 1152 replies
  • October 13, 2020
Hi @ashley f​ , I don't fully get your point.
Is there any filter show "Integrated company"?
If not:
1) You can tag them via API;
2) Create and send custom user attribute;
3) Selec manually from the list and Tag;
BTW: What this tag "Integrated company" means?
  • October 14, 2020
@roy s11​ Thanks--yes, ideally these would be tagged via API, but we haven't built that yet. I know I can select manually from the list and tag. In the meantime, what I really wish I could do is just upload a simple CSV file of Company Names and apply a tag like you can with Users. I don't see that capability available, though 😞
  • Expert User
  • 1152 replies
  • October 14, 2020
@ashley f​ , If you already have a list of companies, you can simply run an API request to tag them.
About the upload CSV file and update company data, you can request this at @Product Wishlist​ Group.
