I would like to make a recursive auto-message that will be sent to the user not once, but each time when some events trigger.
Example
When the user is clicking the button A, the Event-A appears in his event feed. He can click the button A lot of times and each time the Event-A will appear. I would like to send an auto-message to the user each time when Event-A will be triggered
Can it be done with the custom bots, series or any other kind of the apps/products?
There aren't any built-in methods for sending recurring messages (they only ever send to a given user one time) or campaigns in Intercom, but we do have a workaround available! As long as you have the necessary developer resources, you could leverage our public REST API to programmatically send one-off messages (as opposed to ongoing messages, which can't be sent through our API) on a recurring basis.
That said, recurring messages have come up before as a feature request, so I've also given that a bump for our product team to see. š
I don't believe auto-messages will work here, as a user should only ever receive a message once.
Edit: just to be sure, are you also wanting to push an event in Intercom? Or does what I've described above accomplish your goal?
If you do want to push an event, you could do that via Javascript on the same button that triggers the bot. E.g. user clicks -> push event to Intercom via JS -> also open custom bot
A
Anonymous
October 5, 2020
Hey Dennis,
Wanted to understand this a bit more (we're working on this problem right now). Is your use case to send the same message or would you see a use case where you might want to send a sequence of messages more than once? I guess this is more to understand what the problem it is that you are trying to solve.
@Shwaytaj Rasteā I'm also looking to implement something similar.
Ideally I would like each message to have some custom values (from the event metadata?). For example we want to send out a push notification every time a customer pays with their Mastercard. The event may carry info like amount, currency, name of merchant so that it's dynamic everytime it is triggered.
Is this possible?
A
Anonymous
February 10, 2021
Hey Kostas,
One of our teams is working on this right now, so we should have some update on this in the coming weeks . (I've shared your feedback with Zoe, the Product Manager working on this )
Hi! Is there an update on this? I have a use case in which when a customer places an order (they usually place one order per month) I'd like to be able to send them an order confirmation message and reminder about the delivery process. Most of the programs we run are 6-12 months long, so setting up a recurring series every month becomes pretty tedious. From other posts, it looks as though integrating with api still may be only option, but thought I'd check. Thanks! š
@maddie s11ā A fun feature has been released. Not exactly what we discussed, but works for some cases. Now in the "Rules" tab you can set the event, set the limit on how much per timeframe the message will be sent, and set the conditions to stop sending this message to the same user.
On the example from the screenshot, the message would be sent each time when the user login, but not often than once per 2 days until the user will receive the message 3 times.
@denis tā This is not yet fully released. I heard it was beta and on request and many of my Intercom environments do not have it yet.
@maddie s11ā you should contact your Intercom Account Manager and ask this to be turned ON if it already is not. BTW, do we know each other? I work with an Intercom client where there is a lady called Maddie S.
Was this ever released? I'm trying to provide an FAQ bot when customers go to the FAQ page, but it only triggers once and if interacted with, disappears.
I'd love for it to continuously appear when users go to the FAQ page so that the bot can help them through the issue?
Where is this feature? I do not have a 'login success' event rule option? It simple uses the 'who will receive this message' or the 'when to send this' but that only has page url and time on page as options?
Hey Shwaytaj & team, Iām also looking for this feature. My use case is that I use a series to send shipping updates to our customers in a series. So I want them to re-renter the same series every time they order.
Thats fine about the event, however the bot I've created is not part of a series, its a standalone bot but I dont have this option. You mentioned earlier it is a beta feature, it may be that I need this enabling.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
