How do I manually remove someone from a Series or smart campaign?
  • September 18, 2020
  • 336 views
I want to manually remove a user from a Series/smart campaign, how do I do this?
Best answer by Eric Fitz
The best way to manually remove a user from a Series or smart campaign is to use a tag.
For example, you could create a tag called exit_series, and specify in your Series/campaign exit rules that any users with this tag should exit.
Then, when you apply the tag to any user within the Series/smart campaign, they will match the exit criteria.
  • 1630 replies
