Can I delay loading Intercom on my site to reduce the JS load?
  • September 9, 2020
  • 1951 views
Can I delay loading Intercom on my site to reduce the JS load? i.e. only load it after a page is fully loaded for a visitor?
Hello @alex b13​ , Can you try this one?
<script>
 window.intercomSettings = {
  app_id: "APPID" // Replace this with your workspace ID
</script>
<script>
(function () {
  var w = window;
  var ic = w.Intercom;
  if (typeof ic === "function") {
    ic('reattach_activator');
    ic('update', w.intercomSettings);
  } else {
    var d = document;
    var i = function () {
      i.c(arguments);
    i.q = [];
    i.c = function (args) {
      i.q.push(args);
    w.Intercom = i;
    var l = function () {
      setTimeout(function () {
        var s = d.createElement('script');
        s.type = 'text/javascript';
        s.async = true;
        s.src = 'https://widget.intercom.io/widget/b>APPID';
        var x = d.getElementsByTagName('script')[0];
        x.parentNode.insertBefore(s, x);
      }, 5000);
    if (w.attachEvent) {
      w.attachEvent('onload', l);
    } else {
      w.addEventListener('load', l, false);
</script>
  • 1630 replies
  • September 9, 2020
You can modify the Intercom load function by splitting it out like this, and it runs inside a setTimeout function
      // Intercom
        app_id: "<YOUR WIDGET ID>"
     var w = window;
    } else {
        var d = document;
        var i = function() {
            i.c(arguments);
        i.q = [];
        i.c = function(args) {
            i.q.push(args);
        w.Intercom = i;
        var l = function() {
            s.async = true;
            s.src = 'https://widget.intercom.io/widget/lt;YOUR WIDGET ID>';
        l();
The difference is that the part that runs l() normally is onLoad and that gets stuffed up after the setTimeout.
You can also strip out the l() function entirely if you like (and just have the variables declared etc) and just run it, as it’ll be wrapped in a setTimeout function.
  • April 14, 2021
But I don't see any use of setTimeout in the code?
  • Expert User
  • 1152 replies
  • April 14, 2021
<script>
</script>
<script>
(function () {
  var w = window;
  } else {
    var d = document;
      i.c(arguments);
    i.q = [];
      i.q.push(args);
    w.Intercom = i;
        s.async = true;
      }, 5000);
    } else {
</script>
  • May 25, 2021
Thank you Roy! I'm trying to get this working with tagmanager. I can see it firing (on window load) but no sign of Intercom appearing. No console errors either. Any suggestions for me?
<script>
app_id: "<ID>"
(function () {
var w = window;
} else {
var d = document;
i.c(arguments);
i.q = [];
i.q.push(args);
w.Intercom = i;
s.async = true;
s.src = 'https://widget.intercom.io/widget/lt;ID>';
}, 5000);
} else {
</script>
A complete working example would be awesome
Also, Intercom ought to distribute the code using setTimeout by default. Google is punishing us despite brilliant page load speed because the Intercom bubble takes more than four seconds to appear.
