How to implement CSP with Intercom?
We need to add a Content Security Policy to our application that adheres to the following requirements:
  1. include a 'default-src' directive to act as a fallback for other resource types when their policy definitions are absent
  2. set explicit CSP 'script-src' and 'style-src' directives, without the use of wildcard domains
  3. not utilize any 'unsafe'- prefixed directives.
Reading through this article in Intercom Help, i think point#2 above can be addressed (but please confirm), and also advise if points #1 and #3 can work with Intercom (e.g. can we avoid using the 'unsafe-inline'?)
Regarding the original question here is the response from the Support Team:
  1. Yes, a default-src directive can be included in the CSP ✅
  2. Our article lists all of the domains you'd need to allow under the script and style directives
For your third point- unfortunately, removing the 'unsafe-inline' keyword from the `style-src` directive may cause compatibility issues with the Intercom Messenger app. It's important to note that the 'unsafe-inline' keyword allows inline styles to be executed, which is necessary for the proper rendering of the app.
  • November 8, 2023
Would love to have feedback on if there is a way to implement this CSP - anyone knows or has an idea?
Shauna
  • 159 replies
  • November 14, 2023
Hey @Portal Support 👋🏼  Shauna here from Support!
I’ve gone ahead and opened a conversation with one of our support engineers to help you with this 👍🏼
They’ll be in touch with you soon!
Will update this thread with information as soon as this is resolved with support!
Any updates on this? I’m in a similar boat. Adding 100+ hashes that won’t survive an update isn’t a sustainable strategy.
  • March 15, 2024
Experiencing the same issue. Help article seems to be out of date too.
Can we get an update on this?
  • 441 replies
  • April 14, 2024
@Portal Support ​@Shauna ​@Tom Cunningham ​@Tanya  ​@Jacob Cox this is a security risk that has not been mitigated yet by Intercom. This is discussed in multiple threads. I created an item on the Product Wishlist for this CSP/unsafe-inline issue, to hopefully get it prioritised.
Please upvote (and/or add your thoughts):
https://community.intercom.com/ideas/enhanced-csp-compliance-eliminating-unsafe-inline-requirements-8877
