Suggested articles in Messenger with audience targeting
I am using the “Article search” app in my Messenger (on web) and I am not seeing the expected suggested article behaviour described as “Suggested articles will respect your article's targeting criteria”.
I have the Intercom Messenger active on 2 domains, “a.example.com” and “b.example.com”. The articles relevant to each domain are organised into collections. I have created an audience for each domain, targeting “Leads, Users and Visitors” with a “Current Page URL” of “contains {domain}”. For example, for “a.example.com” I have an audience configured to “Current Page URL contains a.example.com”. Within each article, under “Fin”, I have selected “Audience” and then chosen the appropriate audience (either a.example.com or b.example.com).
The expected result is that when I visit “a.example.com” and open the Intercom Messenger, the suggested articles will be the articles which are assigned to the “a.example.com” audience. Likewise, when I visit “b.example.com” and open the Intercom Messenger, I expect to see the suggested articles for the “b.example.com” audience.
Unfortunately, this doesn’t appear to have had any impact: when opening the Messenger on both domains I see the same set of articles, which is a mix of articles from both audiences, suggesting the audience targeting is not working for the suggested articles. I have tried in incognito windows when logged in and logged out to rule out any browser / caching issues.
Are there any additional settings I need to use, or have I misunderstood how audience targeting works?
Thanks,
Best answer by Emma Rutherford
Hi ​@samuel , have you looked at your Messenger settings? There is an option in there called “Connect Messenger with Help Centre”. It allows you to assign different help centres to different messenger brands.
We have 3 different messengers and they all have completely separate help centres this way.
  • January 8, 2025
Hi Emma! Thank you for the response. I forgot to report back that I heard from Intercom support and they have confirmed there is a bug causing the issue I am seeing. They don’t have a timeline for a fix, but it’s on the list.
That said, I wasn’t aware that it was possible to have multiple Messengers. Multiple Messengers would be perfect and would allow me to avoid this bug altogether! I searched for multiple Messengers and found “Configure your Messenger to support multiple brand styles” which is perfect, but, unfortunately, I now see why I couldn’t use this feature: it’s not included in our plan. We’re members of the Intercom Early Stage program which provides access to almost every feature, except “Multiple help centers” and “Workload management”.
Thank you for the suggestion, though.
No problem!
