[Android] Android Sdk Crash failing to resolve LocalSoftwareKeyboardController
  • October 31, 2023
  • 7 replies
  • 1248 views
Integration with the sdk seems to work but when I navigate to the messaging screens it crashes immediately
java.lang.NoClassDefFoundError: Failed resolution of: Landroidx/compose/ui/platform/LocalSoftwareKeyboardController;
        at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreenContent(ConversationScreen.kt:240)
        at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreen(ConversationScreen.kt:119)
        at io.intercom.android.sdk.m5.navigation.ConversationDestinationKt$conversationDestination$5.invoke(ConversationDestination.kt:79)
        at io.intercom.android.sdk.m5.navigation.ConversationDestinationKt$conversationDestination$5.invoke(ConversationDestination.kt:53)
        at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:138)
        at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:35)
        at androidx.navigation.compose.NavHostKt$NavHost$14$1.invoke(NavHost.kt:320)
        at androidx.navigation.compose.NavHostKt$NavHost$14$1.invoke(NavHost.kt:318)
        at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:108)
        at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:248)
        at androidx.compose.runtime.saveable.SaveableStateHolderImpl.SaveableStateProvider(SaveableStateHolder.kt:84)
        at androidx.navigation.compose.NavBackStackEntryProviderKt.SaveableStateProvider(NavBackStackEntryProvider.kt:65)
        at androidx.navigation.compose.NavBackStackEntryProviderKt.access$SaveableStateProvider(NavBackStackEntryProvider.kt:1)
        at androidx.navigation.compose.NavBackStackEntryProviderKt$LocalOwnersProvider$1.invoke(NavBackStackEntryProvider.kt:52)
        at androidx.navigation.compose.NavBackStackEntryProviderKt$LocalOwnersProvider$1.invoke(NavBackStackEntryProvider.kt:51)
        at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)
        at androidx.navigation.compose.NavBackStackEntryProviderKt.LocalOwnersProvider(NavBackStackEntryProvider.kt:47)
        at androidx.navigation.compose.NavHostKt$NavHost$14.invoke(NavHost.kt:318)
        at androidx.navigation.compose.NavHostKt$NavHost$14.invoke(NavHost.kt:302)
        at androidx.compose.animation.AnimatedContentKt$PopulateContentFor$5.invoke(AnimatedContent.kt:942)
        at androidx.compose.animation.AnimatedContentKt$PopulateContentFor$5.invoke(AnimatedContent.kt:933)
        at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:117)
        at androidx.compose.animation.AnimatedVisibilityKt.AnimatedEnterExitImpl(AnimatedVisibility.kt:818)
        at androidx.compose.animation.AnimatedContentKt$AnimatedContent$6$2$1.invoke(AnimatedContent.kt:1256)
        at androidx.compose.animation.AnimatedContentKt$AnimatedContent$6$2$1.invoke(AnimatedContent.kt:824)
        at androidx.compose.animation.AnimatedContentKt$AnimatedContent$6.invoke(AnimatedContent.kt:855)
        at androidx.compose.animation.AnimatedContentKt$AnimatedContent$6.invoke(AnimatedContent.kt:775)
        at androidx.compose.runtime.internal.ComposableLambdaImpl$invoke$1.invoke(ComposableLambda.jvm.kt:129)
Hey there!
Our latest Android SDK release (version 15.6.2) should address the issue with Compose!
  • 441 replies
  • November 5, 2023
Hi @JPInto !
Can you confirm that you’re using our most up-to-date Android SDK? You can find the newest version here!
If you aren’t using that newest version, can you update your SDK and see if you’re still running into this issue?
  • November 6, 2023
Yes it’s the latest.
I believe it’s related to compose 1.6.0
Stripe had the same issue and the solution worked for in this case also https://github.com/stripe/stripe-android/issues/7184
  • 441 replies
  • November 11, 2023
Thanks for confirming that @JPInto !
Issues like this are best handled by writing into the actual Support Team. I’m going to send your message over to them and they will reach back out to you via the email address that you signed up with and get more details from you! Keep an eye on your spam inbox just to make sure you don’t miss their message!
  • December 28, 2023
Hi, i have the same issue as above, is there any resolution to this?
  • 441 replies
  • January 28, 2024
Hi @nquinn9412 !
This issue looks to be related to the version of Compose that some customers are using. You’ll either need to make sure you’re not using Compose version 1.6.0 (which is currently in Beta, I believe) and that you aren’t using dependencies that rely on it. If you are, then I would recommend trying this workaround that is discussed here.
  • February 2, 2024
Hello, we also met this error. It occurres with compose 1.6.0 which is stable now.
Regards
  • 441 replies
  • February 3, 2024
Hey there!
