[Android] Crash from release 15.8.0
I notice that we get a crash from intercom sdk.
It was found in the version 15.8.3 but I notice that I can reproduce this issue from 15.8.0 to the latest version 15.9.1
I down the version to 15.7.1 and that version works.
FATAL EXCEPTION: main
        Process: com.xxxxxxxxxxxx.grocery.staging, PID: 32714
        java.lang.NoSuchMethodError: No static method rememberModalBottomSheetState(ZLkotlin/jvm/functions/Function1;Landroidx/compose/runtime/Composer;II)Landroidx/compose/material3/SheetState; in class Landroidx/compose/material3/ModalBottomSheet_androidKt; or its super classes (declaration of 'androidx.compose.material3.ModalBottomSheet_androidKt' appears in /data/app/~~elspeVOmvltIcyF5hM5qXg==/com.xxxxxxx.grocery.staging-ezzAuVmfBiFxmCt3v8dawA==/base.apk)
        at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreenContent(ConversationScreen.kt:325)
        at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt.ConversationScreen(ConversationScreen.kt:158)
        at io.intercom.android.sdk.m5.navigation.ConversationNavHostKt$ConversationNavHost$2$1.invoke(ConversationNavHost.kt:46)
        at
Best answer by aykut.aydin
Hey @Mariusz Saramak
Thanks for sharing this! It seems like this will require investigation on our end. I have just escalated this as a conversation with our Support Engineering team. You will receive a reply from them via email soon.
aykut.aydin
  • 104 replies
  • July 4, 2024
  • July 10, 2024
My app is experiencing a similar issue. What was the resolution? For now we’re reverting back to 15.7.1. Here is the crash log:
Fatal Exception: java.lang.NoSuchMethodError: No static method HorizontalPager-xYaah8o(Landroidx/compose/foundation/pager/PagerState;Landroidx/compose/ui/Modifier;Landroidx/compose/foundation/layout/PaddingValues;Landroidx/compose/foundation/pager/PageSize;IFLandroidx/compose/ui/Alignment$Vertical;Landroidx/compose/foundation/gestures/snapping/SnapFlingBehavior;ZZLkotlin/jvm/functions/Function1;Landroidx/compose/ui/input/nestedscroll/NestedScrollConnection;Lkotlin/jvm/functions/Function4;Landroidx/compose/runtime/Composer;III)V in class Landroidx/compose/foundation/pager/PagerKt; or its super classes (declaration of 'androidx.compose.foundation.pager.PagerKt' appears in /data/app/~~WOyKT0nEyXlFJfGDurXAMg==/com.[redacted].[redacted]-UhxHh88ovNV74_W1Y_IMwQ==/base.apk!classes3.dex)
       at io.intercom.android.sdk.ui.preview.ui.PreviewRootScreenKt$PreviewRootScreen$2.invoke(PreviewRootScreen.kt:121)
       at io.intercom.android.sdk.ui.preview.ui.PreviewRootScreenKt$PreviewRootScreen$2.invoke(PreviewRootScreen.kt:89)
       at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:118)
       at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:35)
       at androidx.compose.material.ScaffoldKt$ScaffoldLayoutWithMeasureFix$1$1$bodyContentPlaceables$1.invoke(Scaffold.kt:587)
       at androidx.compose.material.ScaffoldKt$ScaffoldLayoutWithMeasureFix$1$1$bodyContentPlaceables$1.invoke(Scaffold.kt:569)
       at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:109)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$subcompose$3$1$1.invoke(SubcomposeLayout.kt:1017)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$subcompose$3$1$1.invoke(SubcomposeLayout.kt:493)
       at androidx.compose.runtime.ActualJvm_jvmKt.invokeComposable(ActualJvm.jvm.kt:97)
       at androidx.compose.runtime.ComposerImpl.doCompose(Composer.kt:3593)
       at androidx.compose.runtime.ComposerImpl.composeContent$runtime_release(Composer.kt:3520)
       at androidx.compose.runtime.CompositionImpl.composeContent(Composition.kt:743)
       at androidx.compose.runtime.Recomposer.composeInitial$runtime_release(Recomposer.kt:1114)
       at androidx.compose.runtime.ComposerImpl$CompositionContextImpl.composeInitial$runtime_release(Composer.kt:3874)
       at androidx.compose.runtime.CompositionImpl.composeInitial(Composition.kt:649)
       at androidx.compose.runtime.CompositionImpl.setContent(Composition.kt:635)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcomposeInto(SubcomposeLayout.kt:516)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:488)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:479)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState.subcompose(SubcomposeLayout.kt:463)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$Scope.subcompose(SubcomposeLayout.kt:895)
       at androidx.compose.material.ScaffoldKt$ScaffoldLayoutWithMeasureFix$1$1.invoke-0kLqBqw(Scaffold.kt:569)
       at androidx.compose.material.ScaffoldKt$ScaffoldLayoutWithMeasureFix$1$1.invoke(Scaffold.kt:451)
       at androidx.compose.ui.layout.LayoutNodeSubcompositionsState$createMeasurePolicy$1.measure-3p2s80s(SubcomposeLayout.kt:725)
       at androidx.compose.ui.node.InnerNodeCoordinator.measure-BRTryo0(InnerNodeCoordinator.kt:135)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate$performMeasureBlock$1.invoke(LayoutNodeLayoutDelegate.kt:316)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate$performMeasureBlock$1.invoke(LayoutNodeLayoutDelegate.kt:315)
       at androidx.compose.runtime.snapshots.Snapshot$Companion.observe(Snapshot.kt:503)
       at androidx.compose.runtime.snapshots.SnapshotStateObserver$ObservedScopeMap.observe(SnapshotStateObserver.kt:502)
       at androidx.compose.runtime.snapshots.SnapshotStateObserver.observeReads(SnapshotStateObserver.kt:258)
       at androidx.compose.ui.node.OwnerSnapshotObserver.observeReads$ui_release(OwnerSnapshotObserver.kt:133)
       at androidx.compose.ui.node.OwnerSnapshotObserver.observeMeasureSnapshotReads$ui_release(OwnerSnapshotObserver.kt:113)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate.performMeasure-BRTryo0(LayoutNodeLayoutDelegate.kt:1775)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate.access$performMeasure-BRTryo0(LayoutNodeLayoutDelegate.kt:40)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate$MeasurePassDelegate.remeasure-BRTryo0(LayoutNodeLayoutDelegate.kt:696)
       at androidx.compose.ui.node.LayoutNodeLayoutDelegate$MeasurePassDelegate.measure-BRTryo0(LayoutNodeLayoutDelegate.kt:672)
       at androidx.compose.foundation.layout.BoxMeasurePolicy.measure-3p2s80s(Box.kt:151)
       at androidx.compose.ui.graphics.SimpleGraphicsLayerModifier.measure-3p2s80s(GraphicsLayerModifier.kt:646)
       at androidx.compose.ui.node.LayoutModifierNodeCoordinator.measure-BRTryo0(LayoutModifierNodeCoordinator.kt:188)
       at androidx.compose.ui.layout.RootMeasurePolicy.measure-3p2s80s(RootMeasurePolicy.kt:38)
       at androidx.compose.runtime.snapshots.Snapshot$Companion.observe(Snapshot.kt:2441)
       at androidx.compose.ui.node.LayoutNode.remeasure-_Sx5XlM$ui_release(LayoutNode.kt:1221)
       at androidx.compose.ui.node.MeasureAndLayoutDelegate.doRemeasure-sdFAvZA(MeasureAndLayoutDelegate.kt:367)
       at androidx.compose.ui.node.MeasureAndLayoutDelegate.remeasureOnly(MeasureAndLayoutDelegate.kt:622)
       at androidx.compose.ui.node.MeasureAndLayoutDelegate.measureOnly(MeasureAndLayoutDelegate.kt:420)
       at androidx.compose.ui.platform.AndroidComposeView.onMeasure(AndroidComposeView.android.kt:1369)
       at android.view.View.measure(View.java:28571)
       at androidx.compose.ui.platform.AbstractComposeView.internalOnMeasure$ui_release(ComposeView.android.kt:309)
       at androidx.compose.ui.platform.AbstractComposeView.onMeasure(ComposeView.android.kt:296)
       at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:7390)
       at android.widget.FrameLayout.onMeasure(FrameLayout.java:194)
       at android.widget.LinearLayout.measureChildBeforeLayout(LinearLayout.java:1608)
       at android.widget.LinearLayout.measureVertical(LinearLayout.java:878)
       at android.widget.LinearLayout.onMeasure(LinearLayout.java:721)
       at com.android.internal.policy.DecorView.onMeasure(DecorView.java:1042)
       at android.view.ViewRootImpl.performMeasure(ViewRootImpl.java:5207)
       at android.view.ViewRootImpl.measureHierarchy(ViewRootImpl.java:3606)
       at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:3978)
       at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:3291)
       at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:11329)
       at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1689)
       at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1698)
       at android.view.Choreographer.doCallbacks(Choreographer.java:1153)
       at android.view.Choreographer.doFrame(Choreographer.java:1079)
       at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1646)
       at android.os.Handler.handleCallback(Handler.java:958)
       at android.os.Looper.loopOnce(Looper.java:230)
       at android.os.Looper.loop(Looper.java:319)
       at android.app.ActivityThread.main(ActivityThread.java:8918)
       at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:608)
       at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)
  • October 10, 2024
Hello!
I’m experiencing a similar issue, any update on this subject?
  • October 10, 2024
aglour wrote:
Hello!
Are you on the latest version of the SDK? If not that should fix the issue.
  • October 25, 2024
We experienced similar crashes and updating to 15.10.3 seems to eliminate them, although we had to be careful and make some extra UI code changes, because 15.10.3 uses a very fresh Compose version.
Well I guess you shouldn't be hacking into my phone and my Facebook account and my email accounts my email here is some examples of you people's work and it's going to stop
https://www.facebook.com/transparency-tools/content-library/dataset/1119037145491882/about/
Hi @George Britton , Ebenezer here from Engineering Support👋.
Could you try updating to 15.10.3 and see if the issue persists?
  • November 3, 2024
15.10.3 seems to have an Issue with Workflows.
I’m also having the same issue.
Intercom SDK version for android: 15.0.1
Hi ​@Jayasankar P R, It’s Mat from the Support Engineering Team 😀
Are you still experiencing this issue with the latest Intercom SDK?
