Can't connect Intercom on Android
  • June 14, 2022
  • 268 views
I set up all the requirements but show me this error
E/Intercom: Failed to register or update user: Unable to resolve host "krb1eidw-android": No address associated with hostname
Best answer by Daniel M15
Hey @mohamed a11​! Daniel from Customer Support Engineering here 🔧
Can you double check that the file google-services.json is in the same directory as your app level build.gradle file?
If so, can you uninstall and then reinstall the app before registering your logged-in user? If you see the "Enabled push messaging" field for this test user is populated with "true", then they should be eligible to receive the push. If not, then there's still an issue with registering a device token for this user.
Can I confirm with you that you're not using another FCM setup in your app? If so, you'll want to check out this step of our installation documentation.
If all else fails, please feel free to reach out to us on the Messenger with some more information. Thanks! 😁
Daniel M15
  • 240 replies
  • June 17, 2022
