Crash on attachments, Android 9
  • November 27, 2024
  • 70 views
   Intercom crashes every time you try to attach any type of content (even embedded gifs) on Android 9
java.lang.NullPointerException
                 	at androidx.compose.ui.node.LayoutNodeDrawScope.drawContent(LayoutNodeDrawScope.kt:49)
                 	at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt$ConversationScreenContent$32$1$1.invoke(ConversationScreen.kt:581)
                 	at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt$ConversationScreenContent$32$1$1.invoke(ConversationScreen.kt:580)
                 	at androidx.compose.ui.graphics.drawscope.DrawScope$record$1.invoke(DrawScope.kt:1077)
                 	at androidx.compose.ui.graphics.drawscope.DrawScope$record$1.invoke(DrawScope.kt:941)
                 	at androidx.compose.ui.graphics.layer.GraphicsLayer$clipDrawBlock$1.invoke(AndroidGraphicsLayer.android.kt:71)
                 	at androidx.compose.ui.graphics.layer.GraphicsLayer$clipDrawBlock$1.invoke(AndroidGraphicsLayer.android.kt:66)
                 	at androidx.compose.ui.graphics.layer.ViewLayer.dispatchDraw(GraphicsViewLayer.android.kt:592)
                 	at android.view.View.draw(View.java:20210)
                 	at android.view.View.updateDisplayListIfDirty(View.java:19082)
                 	at android.view.View.draw(View.java:19935)
                 	at android.view.ViewGroup.drawChild(ViewGroup.java:4333)
                 	at androidx.compose.ui.graphics.layer.view.DrawChildContainer.drawChild$ui_graphics_release(ViewLayerContainer.android.kt:118)
                 	at androidx.compose.ui.graphics.layer.GraphicsViewLayer.draw(GraphicsViewLayer.android.kt:465)
                 	at androidx.compose.ui.graphics.layer.GraphicsLayer.draw$ui_graphics_release(AndroidGraphicsLayer.android.kt:548)
                 	at androidx.compose.ui.graphics.layer.LayerSnapshotV28$GraphicsLayerPicture.draw(LayerSnapshot.android.kt:73)
                 	at android.view.RecordingCanvas.drawPicture(RecordingCanvas.java:292)
                 	at android.graphics.Bitmap.createBitmap(Bitmap.java:1248)
                 	at android.graphics.Bitmap.createBitmap(Bitmap.java:1205)
                 	at androidx.compose.ui.graphics.layer.LayerSnapshotV28.toBitmap(LayerSnapshot.android.kt:47)
                 	at androidx.compose.ui.graphics.layer.GraphicsLayer.toImageBitmap(AndroidGraphicsLayer.android.kt:864)
                 	at io.intercom.android.sdk.m5.conversation.ui.ConversationScreenKt$ConversationScreenContent$32$2$1.invokeSuspend(ConversationScreen.kt:592)
                 	at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
                 	at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
                 	at androidx.compose.ui.platform.AndroidUiDispatcher.performTrampolineDispatch(AndroidUiDispatcher.android.kt:81)
                 	at androidx.compose.ui.platform.AndroidUiDispatcher.access$performTrampolineDispatch(AndroidUiDispatcher.android.kt:41)
                 	at androidx.compose.ui.platform.AndroidUiDispatcher$dispatchCallback$1.run(AndroidUiDispatcher.android.kt:57)
                 	at android.os.Handler.handleCallback(Handler.java:873)
                 	at android.os.Looper.loop(Looper.java:193)
                 	at android.app.ActivityThread.main(ActivityThread.java:6669)
                 	at java.lang.reflect.Method.invoke(Native Method)
                 	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
                 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
Best answer by Shaq Payne
Hey Shaq with the Support Engineering team here at Intercom! 🙂
I’ve received reports of this in the past but we’re not currently investigating any widespread issues related to this. Can you confirm which version of the SDK you’re using and upgrade to the latest version found here if you aren’t already?
Shaq Payne
  • 27 replies
  • December 2, 2024
  • December 2, 2024
Hello. We use latest sdk version: 15.11.2
Shaq Payne
  • 27 replies
  • December 30, 2024
Thanks for confirming, are you still seeing this? If so, I can go ahead and escalate this further.
  • January 1, 2025
Still having this issue, I’m using react native SDK version: 8.1.0
  • January 4, 2025
Have the same issue! Whats wrong with android developers at intercom?
Every release — a lot of crashes & problems! Ios works fine! Dislike!
