When running unit tests in Xcode Cloud we often get a test failure because the tests failed to start. In those cases we get a spindump indicating that there is a deadlock caused by something Intercom does as a result of [UIBarAppearance init] being called.
Anyone seen something similar? It seems to be related to a global initializer so just linking against Intercom will cause the problem. Just to be sure Iβve changed our code to not call any Intercom methods when running as part of XCTests but it appears to still be happening.
