React Native: 404 Resource not found
  • May 14, 2024
  • 210 views
[Error: ERROR - [HTTP 404] - Resource Not Found]. when I try to use one of the login function.
we are using or trying to present the Intercom Messenger.
const loginWithIntercom = async () => {
     const status1 =  await Intercom.setUserHash(user.id.toString());
     console.log('status hash : ', status1) // true
      const status = await Intercom.loginUserWithUserAttributes({
        userId: user.id.toString()
      }); // throw 404 not found error
      console.log('login success : ', status);
I’ve checked in the native code that everything is configured as it should be after running npx expo prebuild.
how to deal with this issue ?
We are using :
expo SDK: 51
react-native: 0.74.1
intercom/intercom-react-native: 7.1.1
Hi iamMAHAM, It’s Mat from the Support Engineering Team 😀
If you are unsure how to modify your code please refer to our Example React Native App.
You can find similar working code structures, so you can find your inspiration there.
