How can we launch a product tour from a checklist on a unique/dynamic URL?
I’m trying to setup an onboarding checklist in which multiple steps will launch product tours. I have the first step setup and functioning fine, but the subsequent steps/product tours I cannot seem to configure to launch when/where it is needed. Here’s the issue:
Our customer’s URLs are : subdomain.domain.com …..
When a customer creates their account and logs in for the first time, they are brought to their homepage. The checklist appears and the first item in the checklist launches a product tour on that page. There’s no dynamic aspect to that URL, so we can simply setup the “Use your tour everywhere” setting to use {subdomain}.domain.com
That tour has them create a case/project in their dashboard, which generates a new page/URL. The issue arises here, because that URL is different every time, for every user, however, the URL itself is not unique to a user, meaning any user in that dashboard (which there are typically multiple) can access that case/project/URL.
The URL ends up being something like: subdomain.domain.com/cases/1234567 (this number is unique and generated at the time of the case being created).
Now I run into the issue of the next product tour. I can’t setup a URL for the “use your tour everywhere” setting that will account for the unique number generated in the URL.
I can only seem to setup the tour to show automatically, and then set some conditions for the URL, but that doesn’t allow for the onboarding flow that we would like to have, as we want them to complete the tours in sequence.
Hi Cory McArthur, It’s Mat from the Support Engineering Team 😀
This is very niche use-case for setting up a Product Tour. The only way I can see as a workaround would be to set Show my Tour Automatically with an audience rule (URL starts or Ends with) to target the mutual part of the URL for your customer (assuming that there is one).
And then set some Trigger Rule to show the Product Tour.
It won't be triggered with the button, though. That’s the trade-off.
  • 441 replies
  • December 17, 2023
Hey there @Hillary !
It sounds to me like you could add a dynamic variable to the ‘Use everywhere’ URL that would get inserted when the User clicked on the Tour step in the Checklist. It would look something like this:
  1. Create a custom attribute for the User where the Case number will (eventually) be stored.
  2. Create a URL for the tour that inserts the Case attribute at the end of the URL like shown below
  3. When you assign the case number to the user, make an update call in Intercom to update that custom attribute with their case number.
  4. Now when your customer clicks on that Tour step in your checklist, the case number should get dynamically added and the customer should be taken to the correct URL!
Here’s my ideal scenario:
  1. I set up an intercom checklist that our users can trigger while on a page that they can edit.
  2. I add a tour as a checklist item
  3. When the user clicks the button - the tour shows.
The problem with this approach: In order for a product tour to show via a checklist I have to “Use your tour everywhere” and insert a URL. I’d rather the tour just show because the user clicked the button inside the checklist.
I already tried disabling “Use your tour everywhere” - but when a tour button is clicked an error is logged and nothing happens.
So.. I’m stuck trying to work around this limitation by adding a dynamic URL… However, the above scenario doesn’t work for me - because my customers can have several unique URLs that are associated with their account. So how can I dynamically support multiple URLs for a single customer?
Ideally I’d like to just use the current URL (or NO URL at all) to trigger the product tour within the intercom checklist
Hi ​@mateusz.leszkiewicz
Offering a different perspective here: This isn’t  a niche use-case for setting up a Product Tour. With any complex SaaS product (e.g. mine is a no-code app building platform), the product experience starts on a dynamic URL.
While I am trying Jacob Cox’s solution now, setting up new events/attributes requires more engineering support than I have required for previous tools like Pendo that allow for Regex URLs.
Maybe this is a product feedback request you could take into consideration, because it is a significant limitation.
@Intercom Utility,
Can you check if this feature has been recorded on our Product Wishlist in our Community? You can search and upvote existing requests or create new requests 🙌 Check out the quick guide on how the Product Wishlist works here. Note that you must be logged into the Intercom Community to access the Wishlist. You can log in with SSO or log in as a guest at the top right of the page.
