While Creating a product tour, I noticed that when trying to assign a pointer to a pop-up window, that when trying to add the descriptive text in, it will not allow you to type anything. Even adding a post instead will not allow text to be entered into the description as long as the pop up is open.
Product Tour Pointers Wont allow text to be added in pop ups
Best answer by cameron.gumley
Hi
Does your site use âfocus trapping, and if so, have you tried adjusting the "focus trapping" settings in your site as detailed in this article HERE?
If you're building your Tour and it includes accessing a pop-up window/modal, "focus trapping" can cause some issues in the build stage like making it impossible to type content in the tour steps (as youâve seen here) and/or being unable to select elements within the modal to use in subsequent steps. Turning "focus trapping" off while you build the Tour should help with this.
This only impacts the Tour builder and not the way the Tour will be displayed to customers. While building the Tour youâll need to have âfocus trappingâ off, but as soon as youâre done building and the Tour is ready to go âLiveâ you can re-enable âfocus trappingâ and the Tour will be unaffected when shown to the end-user.
Give this a try and let me know how you go đ
Join the Intercom Community đ
Login to the community
