Intercom survey not showing and track event not working when user_id included on intercomSettings
  • December 27, 2024
  • 44 views
Hi,
I'm trying to show intercom surveys and track user events on my website, but the surveys don't show up if I add user_id in my intercomSettings via Javascript API, also I keep getting forbidden requests to track user events, can anyone help?
Is there any requirement to use event tracking such as secure mode enabled or added something on intercomSettings?
Best answer by Emilygav
Hey ​@Irsan Mardiansyah, Emily here from Support Engineering at Intercom 👋🏼
To track user activity and set custom attributes in Intercom using JavaScript, you should use the Intercom('update', user) method to update user information and the Intercom('trackEvent', eventName) method to track events. For setting a custom attribute such as is_admin, you would include it within the user object like so:
Intercom('update', {
  custom_attributes: {
    is_admin: true
This will update the user's profile with the custom attribute is_admin set to true. If the attribute is_admin is not recognized by Intercom, it should be created automatically upon updating the user with this attribute.
To track an event, such as a user filling out a survey, you would use the trackEvent command. Here's an example of how to track a button click event:
window.intercom('trackEvent', 'survey-completed');
This will send an event to Intercom indicating that the survey was completed. Make sure that the event name matches the one you have set up in your Intercom settings for triggering surveys.
If you're following the steps from the Intercom help article and it's still not working, ensure that the Intercom JavaScript API is correctly installed and initialized on your website. The event tracking should be set up as described in the documentation, and you can include metadata with the event for more detailed tracking if needed.
  • 296 replies
  • December 29, 2024
@Irsan Mardiansyah  Can you share more about your website? Is it a one page web app or standard website?  On a single page webapp you’ll need a different code for Intercom and/or are you not using the Intercom JS and trying to custom code something for tracking here?
@Nathan Sudds It’s standard website with more than one page, I use intercom JS to trigger survey by code and want to track the users activity whenever the user fill the survey. I use this reference https://www.intercom.com/help/en/articles/175-set-up-event-tracking-in-intercom#h_7816b125af and still not working.
Emilygav
  • 84 replies
  • January 10, 2025
    is_admin: true
