Access tokens need to be regenerated
#1
Hi,
I’m working within a private application that needs to make a few calls to the Intercom API. We generated the access tokens a while ago, and when I went to view them, I notice that some of them need to be regenerated. Is there any way to create a permanent token? Having to change the several that we need for our clients and sandbox will require changing our configurations each time.
Even though ours is technically a private application, I suppose that it might be necessary to set up OAuth access if we can’t depend on the tokens being stable.
Thanks in advance,
Mark
#2
Hey @mpemburn :wave: Tokens never expire, but you do need to regenerate if you change the scopes that the token has access to. Otherwise, you’re good to go (provided it’s for private use) :+1:
#3
Thanks! I think we did change the scope on one or more of these.
