Android SDK crash: ReactionInputView.highlightSelectedReaction > IndexOutOfBoundsException
I’ve got the following crash report that’s come in via Crashlytics.
I’m using SDK 5.4.1
Unfortunately I don’t have any context or recreation steps, just the stacktrace
Fatal Exception: java.lang.IndexOutOfBoundsException: Index: 2, Size: 2
at java.util.ArrayList.get + 437(ArrayList.java:437)
at io.intercom.android.sdk.conversation.ReactionInputView.highlightSelectedReaction + 232(ReactionInputView.java:232)
at io.intercom.android.sdk.conversation.ReactionInputView$2.handleTouchMove + 198(ReactionInputView.java:198)
at io.intercom.android.sdk.conversation.ReactionInputView$2.onTouch + 161(ReactionInputView.java:161)
at android.view.View.dispatchTouchEvent + 12228(View.java:12228)
at android.view.ViewGroup.dispatchTransformedTouchEvent + 3075(ViewGroup.java:3075)
at android.view.ViewGroup.dispatchTouchEvent + 2720(ViewGroup.java:2720)
at android.view.ViewGroup.dispatchTransformedTouchEvent + 3081(ViewGroup.java:3081)
at android.view.ViewGroup.dispatchTouchEvent + 2734(ViewGroup.java:2734)
at com.android.internal.policy.DecorView.superDispatchTouchEvent + 450(DecorView.java:450)
at com.android.internal.policy.PhoneWindow.superDispatchTouchEvent + 1829(PhoneWindow.java:1829)
at android.app.Activity.dispatchTouchEvent + 3336(Activity.java:3336)
at androidx.appcompat.view.WindowCallbackWrapper.dispatchTouchEvent + 69(WindowCallbackWrapper.java:69)
at com.android.internal.policy.DecorView.dispatchTouchEvent + 412(DecorView.java:412)
at android.view.View.dispatchPointerEvent + 12480(View.java:12480)
at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent + 4986(ViewRootImpl.java:4986)
at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess + 4796(ViewRootImpl.java:4796)
at android.view.ViewRootImpl$InputStage.deliver + 4328(ViewRootImpl.java:4328)
at android.view.ViewRootImpl$InputStage.onDeliverToNext + 4381(ViewRootImpl.java:4381)
at android.view.ViewRootImpl$InputStage.forward + 4347(ViewRootImpl.java:4347)
at android.view.ViewRootImpl$AsyncInputStage.forward + 4474(ViewRootImpl.java:4474)
at android.view.ViewRootImpl$InputStage.apply + 4355(ViewRootImpl.java:4355)
at android.view.ViewRootImpl$AsyncInputStage.apply + 4531(ViewRootImpl.java:4531)
at android.view.ViewRootImpl.deliverInputEvent + 6911(ViewRootImpl.java:6911)
at android.view.ViewRootImpl.doProcessInputEvents + 6885(ViewRootImpl.java:6885)
at android.view.ViewRootImpl.enqueueInputEvent + 6842(ViewRootImpl.java:6842)
at android.view.ViewRootImpl$WindowInputEventReceiver.onInputEvent + 7022(ViewRootImpl.java:7022)
at android.view.InputEventReceiver.dispatchInputEvent + 186(InputEventReceiver.java:186)
at android.view.InputEventReceiver.nativeConsumeBatchedInputEvents(InputEventReceiver.java)
at android.view.InputEventReceiver.consumeBatchedInputEvents + 177(InputEventReceiver.java:177)
at android.view.ViewRootImpl.doConsumeBatchedInput + 6989(ViewRootImpl.java:6989)
at android.view.ViewRootImpl$ConsumeBatchedInputRunnable.run + 7045(ViewRootImpl.java:7045)
at android.view.Choreographer$CallbackRecord.run + 921(Choreographer.java:921)
at android.view.Choreographer.doCallbacks + 729(Choreographer.java:729)
at android.view.Choreographer.doFrame + 658(Choreographer.java:658)
at android.view.Choreographer$FrameDisplayEventReceiver.run + 907(Choreographer.java:907)
at android.os.Handler.handleCallback + 790(Handler.java:790)
at android.os.Handler.dispatchMessage + 99(Handler.java:99)
at android.os.Looper.loop + 164(Looper.java:164)
at android.app.ActivityThread.main + 6524(ActivityThread.java:6524)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run + 451(RuntimeInit.java:451)
at com.android.internal.os.ZygoteInit.main + 888(ZygoteInit.java:888)
Hey @kassim - Can I ask you to write into our Intercom messenger or email us at team@intercom.io, so we can add a little more context to investigate this a little bit more closely? It will also be a better way for us to keep you in the loop, if this takes a deeper dive. Feel free to link to this post in your message! Thanks!
Hi, we are having the same issue in our application (intercom sdk v6.0.1)
Please find details about this crash in the link below:
This crash is happening every time we click an emoji to answer a question.
