API call to fetch help articles?
Is there some API method that I can use to download help articles?
Get the list of articles on a topic (as a precursor?)?
Hey Kyle :wave:
At the moment Intercom doesn’t have a built-in way for exporting Articles, or an Articles API. This is definitely something the team has looked at though, and I’ll flag this for you to make sure it stays on their radar.
In the meantime, there is a workaround I can offer. It would take a bit of DEV muscle but would allow you to retrieve all your public Articles by building a scraping tool using HTTP.
Here is a tool you can use to do that: https://github.com/lloydliyu/intercom-articles-scraper
I do want to emphasize that since this workflow isn’t officially supported by Intercom, our support options would be very limited. Also, as noted this would only allow you to retrieve your public articles, any private articles would not be included.
I’ve been looking for this too - it’s a shame not to have any support for Articles in the API…
Hey @Matthew_Cockerill and @Kyle_Hart - we actually have public beta access for the Articles API now in our Unstable version of the API. Just bear in mind that everything in that version is subject to changes. Enjoy :raised_hands:
