Cordova Intercom build error
#1
When I build my app I found the following error.
We tried all configurations according by intercom configuration link and found this.
#2
Hey @anderson.viana, I haven’t run into that before but based on the details it looks like it either has the wrong URL or that the the file isn’t being hosted there?
If that doesn’t help, if you share a sample project with the error happening along with the versions of cordova and cordova-android that you’re using we can try dig into what is happening :+1:
