Custom bot from same button anywhere on domain
#1
Hi All,
Hope you can help me with this, any suggestions are welcome.
My use case is as follows:
I have build a “custom bot from button” that is launched from an element on https://www.myhomepage.com/. The element is labeled “Request a demo” sits in the top navbar and is visible throughout the website.
This works fine on the homepage but of course a vistor might want to request a demo from https://www.myhomepage.com/pricing or any other link
Is there any way to support this use case by, for example, using javascript to start up the custom bot. Or better yet introduce wildcards in the URL (doesn’t work I tried this).
Thanks in advance,
Niels
#2
Hey there Niels! :wave:
Thanks so much for taking the time to write in! For this specific use case the best thing to do would be to create a custom bot for each of those buttons on any pages where you’d like that action to happen.
This is a really great example of Custom Bots from a button and I’m going to share your feedback with our product team as a feature request! I’m confident we can come up with a solution like this going forward that will allow you to target multiple pages with buttons. :smiley:
I hope this helps, we’re here if you have any other questions!
Russell
