Duplicate okio class issues with 8.0.0 and 8.0.1
Hello. I’m getting this compile time error when trying to use Intercom 8.0.1
Duplicate class okio.-Base64 found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-DeflaterSinkExtensions found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-DeprecatedOkio found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-DeprecatedUpgrade found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-DeprecatedUtf8 found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-GzipSinkExtensions found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-GzipSourceExtensions found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-InflaterSourceExtensions found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-Platform found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
Duplicate class okio.-Util found in modules intercom-sdk-base-8.0.1-runtime (io.intercom.android:intercom-sdk-base:8.0.1) and jetified-okio-jvm-2.8.0 (com.squareup.okio:okio:2.8.0)
This did not occur in 7.2.0. I’ve tried using the Gradle exclude feature but it doesn’t help.
Hey there! Could you write into Intercom via the Messenger with further details and a full stack trace so one of my engineering teammates could dig deeper into this?
I got the same issue when updating to version above 7.2.0. Could you please post the solution here once that’s solved?
Same issue, can’t upgrade from 7.2.0.
@Ricky_M I wrote into Intercom via Messenger like you suggested. Not sure if your engineers saw it or not, though.
