Input_values coming back as empty string
#1
Hello!
The input_value we’re getting in the request body for a submit API call is returning empty string.
Like this:
‘input_values’: {‘field-name’: ‘’}
The field is a single-select. The options are “yes” or “no”, so I should be seeing either “yes” or “no” there.
This suddenly started happening this afternoon about an hour ago.
#2
This is happening on my messenger app as well. Where you able to solve it Jenna?
#3
Something that I noticed is that it starts to come back with a value after you click on it twice…
#4
Hey @jenna and @marino Thanks for highlighting this! We’re digging into it on our end, and we’ll let you know here as soon as we have an update. :+1:
#5
@jenna and @marino We’ve just released a fix that should have everything back to normal for you. :ok_hand: If you’re still seeing anything similar, do let us know!
#6
@jackjenkins I just tested it and confirmed it works. Thanks!
